PDF Generator - Problem with tables
Hi everyone!
@raylan.oficial
I used this plugin for a long time and recently I started having trouble creating pdfs with tables. When I remove the table, it works ok, but when I inser a table inside the group that I am converting to pdf, the file turns out to be empty.
Do any of you know what can I do to fix this?
Ps: I am having the same troube with other plugins. When there is a table inside the group, it doesn’t work.
All those plugins that kind of take a screenshot of the element and then turn it into a PDF use a library called html2canvas, so I was going to say that the table element might be conflicting with it. But I stopped there to install the plugin you mentioned, tested it, and it worked.
Would you mind sharing some screenshots of how you’re trying to do it?
Built opensource plugin for the same : mergepdf Plugin | Bubble . Please DM if any customised needs required for the same.
