Please Help - Multi step form
Hi there,
I have a huge multi step form with 40 inputs / dropdowns etc
Everyhting works find on test mode but for some reason on the live version it does work. it shows the columns as empty.
Do you know how to fix this?
on test mode even if there is empty filds the listing gets created and it shows whatever is filled. but on the live version it doesnt show anything
We need more information in order to help you. Have you checked your privacy rules? Use the debugger and check if the data types that should be loaded are empty. If so it’s probably due to missing privacy rights.
