Another issue i m facing is that send native token is working with ETH, but metamask shows an error in transaction when BSC is used as below-
How to handle this & sort payments with BNB?
Check the user balance, if it is lower that the amount in your transaction, it will fail. Like for example in your screenshot you have 0 BNB
Hi
I think this is a great Plug-In and i am sure that i am missing a basic thing. I would like to use this plug-in as a mint button for my NFT collection. Everything works fine, but since i want the minting to cost 0.04 eth which is 4*10^16 wei, i am getting an error message. The way this plug-in works with these big numbers is by using 4.0000000000 e16 and the plug in can not work with decimals.
Is there any workaround?
Best,
Nico
Hello there, can I create and transfer NFT with this plugin?
