Hi Daniel,
yes, our snipper is written so that any requests made to mydomain.com/dynamicurl will be redirected to mydomain.com/id/dynamicurl
Itâs done with the plugin âBrowserâ
Hi, @levon thanks for this tutorial! Iâm having some issues setting it upâŚ
Cloudflare does not accept the character â it seems. I get invalid errors when I enter them. Maybe Iâm doing something wrong. Look at this:
So I replaced them with " probably not okay since it is not working for me. At least it no longer complains about line 1 when I remove â.
Also, Cloudflare is updated and looks different now. They are linking to a new workers dashboard. There I set up a new subdomain (namehere.workers.dev) for workers which I donât understand at all so I went back.
And I can enable the script but I canât actually find where to add routes where the script is disabled. I think they moved the âroutesâ tab as well.
So what happens on my side?
On the live site, nothing, just 404 pages.
On Cloudflare preview Iâm getting this error:
1cd7499bcfd2fht7ebc7f2c918d3170.cloudflareworkers.com redirected you too many times.
Also getting this in the CF preview mode console if it helps:
I should note that I didnât pay for anything, Cloudflare says it supports 100k worker requests a day for free. Although you need to pay for workers KV, do we need workers KV support?
@levon Do you have an idea of whatâs going on? Do you think you can show me your worker script now? How is it not invalid for you? And where do you add routes where the script is disabled?
Edit:
I see whatâs going on here, when you copy the ( â ) character and paste it into Cloudflare, it turns into another invalid character.
See the difference when pasted:
We need to fix it manually to:
this is how the script looks for me
i see that they crate a separate dashboard for workers, but i can still access the old editor.
The routes indeed have been moved - i can see them now in the workersâ home page (when you go to cloudflare â choose domain - > click on workers - you see the option to add routes).
If the same script produces error I would suggest to reach out to cloudflare support or post on their forum.
We didnât change anything on our side since posting this thread her and it still works.
i think though I have added my credit card details from the vey beginning and iâm getting charged about $5/month for the workers to run - maybe thatâs the reason?
Thanks
@levon My routes are not working as I think they should.
I have set my redirect script to: https:/domain.com/*
And a bypass on https:/domain.com/dash*
Now if I type https://domain.com/dash, it still redirects to https://domain.com/id/dash
I canât really explain this, any thoughts?
is solutions in this post still available regarding to the implementation of cloudflare on bubble ?
I guess it wonât work.
Youâll be using CNAME records with DNS only type (not proxied) and for the workers to run the DNS Records have to be actually proxied.
Thank you
Hey @levon! Did you manage to find a new workaround for pretty URLs (mydomain.com/dynamiclink) that takes the implementation of cloudflare on bubble into account?
Thank you,
Zack
Hi Zack,
the solution that we outlined in the first post still works.
check this out http://mydoors.to/demoproperty
Iâve spent days trying to get it to work
Your script works great but when my DNS records are proxied, bubble is no longer able to read them⌠Could you share how your DNS records are configured? Are you using bubbles A records?
yes, we use A records,
is your Bubble app new? When did you create it?
which IP addresses does your DNS point to?
My app is only a few weeks old. 3/4 weeks at most.
104.19.241.93
104.19.240.93
i switched zeroqode.com to these IP address with an A record and the proxy is on, seems to be working fine. But Iâm not sure why itâs not working for you - maybe worth to shoot an emailto support@bubble.io ?
Thank you for showing me itâs possible! I have sent an email to Bubble support
@levon Hi, how do you manage to get dynamic Metatag data for SEO title, description, and images to show for http://mydoors.to/demoproperty?
Hi John,
on the property page open the page properties (double click outside of the main canvas)
then set the dynamic values as on these screenshots:
hope this helps
Zero Code Conference 2020. October 7-8
Levon Terteryan
Founder @ Zeroqode
I use URL Router plugin, but in âDo a Search forâ function for SEO, it doesnât allow me to get path from the url. How do you make a search function work?
Letâs say: mydomain.com/id/thomas
How do you get the path âthomasâ from the url since URL Router plugin is not allowed?
Appreciate your help!
Since going to domain.com/dynamiclink will lead you to a 404 page by default, it is technically possible to build out a profile page right on the 404 error page
@levon do you know if thereâs any impact on SEO by doing that or if this is just a dumb idea?
