Preventing binding on icon click
I have added binding to a section - is it possible for the user to click and icon and then for binding to be disabled. I essentially want the user to be able to edit the content, then accept the change and the ability to edit be removed.
You mean you want to the User to be able to decide whether or not to use autobinding?
Or you just don’t want to use autobinding at all?
Then don’t enable auto binding. Just make the default value of the input whatever field it comes from and then make changes to that field based on the input’s value when the user clicks save.
If you want them to be able to toggle auto binding, use two multiline inputs that are conditionally displayed depending on the toggle.
I want them to have done the edit then remove autobinding.
This worked perfectly
