I get this error message while I’m trying to configure an API Connector entry:
"There was an issue setting up your call.
Raw error for the API
{“message”:“certificate has expired”,“args”:{“origin”:“native error”,“code”:“CERT_HAS_EXPIRED”,“outer_stack”:{“message”:".wait() was called here",“args”:{}}}}"
Someone can help me? This connector is to access my Node JS API, hosted in Kinghost!
What is the URL of your Node JS API? If the URL you think you are trying to connect to, you think has a valid SSL certificate, then maybe you are connecting to something else?
Is the URL correct? maybe it is redirecting to a page with an expired certificate? What happens when you put that URL in your browser? Expired certificate warning?
I think the URL is the correct one! A host my API in Kinghost. I will check if there is some kind of redirection.
When I call it from a browser, i get a message from my Kaspersky: “This certificate or one of the certificates in the certificate chain is not up to date. view certificate…”
