Every time I do editing in responsive it always time out,
even though the internet is not a problem
Has anyone ever experienced this?
Is this ONLY happening with a specific page? Or does this happen with every page?
I tried it only happened on the Index page
on other pages normally
Good. So chances are there’s an issue with something on that page specifically that’s triggering this problem.
I recommend duplicating your index page.
Then try again with the newly created page.
If the error still occurs, start removing plugins that you have on your page (refreshing after changes). It’s possible your app editor can’t handle everything that’s going on. Plugins tend to be the root of the issue.
If none of that works, file a bug report with Bubble.
