Problem with 'Air date/time picker' when used in a Repeating Group
Hello.
I am using the “Air date/time picker,” and I have an issue with the initial data.
When I use it on a regular page, it works fine.
However, when I have the “air date” in a REPEATING GROUP, the value is displayed as a placeholder instead of the actual value. I even changed the color of the placeholder.
How should I use it?
Captura desde 2023-07-24 19-22-37
Edit: Ignore the date shown in the air date/time picker.
Thanks
Hello @vel,
Sorry for the late reply. :pray:
Unfortunately, the issue you reported is not reproducing on our side. Could you please provide a screen recording showing the issue and your setup? Also, please make sure you are using the latest plugin version.
Appreciate your cooperation!
Best regards,
Zeroqode Support Team
