I have an issue with bubble.io. I have a backend workflow, but every time I call it, it retrieves an old one that isn’t in the flow. It’s as if it were stuck in the cache. What can I do. How do I detect it? The backend that no longer exists used to create a record every 1 minute. The current one should do it at the start of the day. What’s happening is it performs the first action, but afterwards, it calls the old one that doesn’t exist. Is it possible that this is saved in some cache? Why is this happening?"
Probably not
Might still actually have the workflow in the system and just have it renamed so do not recognize it
I will try it
lo copie cambie el nombre y se soluciono.
