button does not work only works on top
I tried bring to front group and icon without solution
ezgif-5-6ea626e5ca
Hey @michelvsouza ,
Will need to have some sort of access to the editor to help you debug this kind of problem.
Best,
Alex
how do i do it? I’m new here
Hi!
A good practice is to put the icon into a group and make that group clickable instead.
Another perk is that u can customise ur new delete button like make the icon white and the group red with rounded corners for example.
Just take note that only the icon will have the tooltips (on hover) option.
Hope that helps!
