Hi! Why it needs something else?
Impossible to say without knowing more…
What does the issue checker say? (it should tell you the problem).
But most likely it’s a ‘type’ mismatch. What type is the custom state? And what type is the Searchbox’s value. The most likely answer is they are not the same.
