Problem with Hidden/Collapse groups/pages on dashboard project
I have a problem about hidden / collapsed groups. I am building a dashboard with a slider menu, each option calls a group / page but, the scroll bar does not reduce, there is a large blank space. I checked the option to hide from each group.
I configured the states and conditions and then the workflow. Below are some imagens to show the entire configuration of each group. Each main group has the same configuration. However, in (Dev> Preview) the scroll bar does not reduce.
What I have to do?
Hey Daniel
First of all, check it you don’t have any overlaping elements.
Tha collapse action fails if elements overlap with the hiding/showing groups.
That is the most frequent issue To cause failures.
Best regards!
