Problem with HTML element when extracting element of a list
I am creating a application in javascript which i will implement in my website.
I want to get some ID of the first item on a list of data, but it’s not working properly, here is the problem:
InkedScreenshot_3_LI
It gets stuck and stops the applications…:
this happens if i try to obtain data from a list, but if i try getting from a simple data text, it works:
Screenshot_4
There are no errors in bubble or in my code, i tested many times…
Can you setup a demo app which shows the same problem?
The second screenshot appears to be missing a double quote after the dynamic text.
It didn’t show up double quote or i corrected it afterwards. There is definitely a problem with bubble lists in html element.
How i corrected this was using toolkit element, and extracting the list from there. Afterwards i made a call to my HTML element function, with the data as argument.
