Problem with margins when designing responsive
Hi all,
I designed some Navigation Cards in Material Design Style for the home screen of our App. I left-aligned them, min with is 99 and max width 100. For every second card I choose “Wrap to previous line when page is stretched”. The result is almost as I want it. Except I cannot get it to have some horizontal margin between the cards in the stretched view. See Screenshot.
Does anyone have a clue how to fix this? Appreciate your help :slight_smile:
Hi! :wave:
Place your cards inside another group and create the margins you want between this card and it’s parent group. :+1:
You can also check Frames, to help you build and understand margins…
Great, that worked well! Thanks for the quick help
