Problem with responsive desigh on mobile (forced mobile version)
Hi!
I have a site that is designed as responsive, but the problem is that some mobile browsers don’t use it, instead of creating and forcing some kind of a “mobile” version, especially if it’s accessed within Messenger, etc. On Chrome, I can check the option to see the desktop version and then it works fine, but even then it’s not what is loaded as a default.
Because of this, I had to create a second, mobile version for most pages and it’s a pain, trying to maintain two versions of the same.
So, the question is: is it possible to block the mobile version / force responsive no matter when the site is viewed and if yes, how to do this?
I’d appreciate the help :slight_smile:
