I am having an issue with pulling URL Parameters for use in a dropdown. I need to create a uniques url using parameter keys. The keys then will be used in a dropdown that will then filter a repeating group.
I am using the key, ministry_filter and my url parameters are defined as as option set, url_parameters. In the picture below, if a user changed the dropdown, it send the parameter to the url. This part works.
However the repeating group lookup is not working. When I define the parameter name, it accepts everything (see first image below). However, when I do the lookup, it is red and will not let me complete the lookup (2nd image below).
Parameter name should be "ministry_fill[...]" as in text you’re passing in the image 1 and then the type has to match the ministry data type i.e the option set
