hello,
I want my x icon to be on the empty boxes of the repetitive group.
how can I do please? thanks.
Hi @rpz
Have you tried to do a condition for that, if the field is empy then show that X ?
yes, but not fonctionnaly
i tried this:
but but does not work…
my problem is: I would like that in the empty boxes the X appear and be replaced by a + to add photos
Hello Julien,
I believe mxolispn solution doesn’t work because your repeating group only shows the existing data so it shows empty boxes for the other images because there is no data to show.
A few ideas that can maybe help you:
- Add a transparent image to your list and find a way to distinguish this image from the others so that clicking on it would allow adding a new image to your list (for example every image has a number added to it, your RG shows the images going down (5,4,3,2,1,0) and the transparent image is 0)
- Add an image in front of the RG(repeating group) that moves depending on the number of pictures you have
Hope this helps!
thanks but not ideal…
I have successfully found it by changing my repeatinggroup into a separate group with an image uploader in each and an x on each
