Today, mysteriously, the CamCapture and QR plugins stopped working. Has anyone else experienced similar issues?
@ZeroqodeSupport you know something for that
Hey @khaled ,
Thank you for contacting us.
We’ve checked both the CamCapture and QR plugins on our end, and everything is working fine. We haven’t received any reports from other users regarding issues with these two plugins, so it seems to be functioning as expected.
However, if you’re facing issues, here are a few Bubble-specific troubleshooting tips that might help:
Check Your Plugin Settings: Double-check the configuration settings for both plugins in the Bubble editor. Ensure that everything is set up correctly, and no necessary options are missing.
Review the Workflow: Make sure the workflows triggering these plugins are correctly set up. If the plugin isn’t being triggered as expected, the issue might lie in the workflow logic.
Verify Permissions: For plugins like CamCapture, make sure your app has the correct permissions to access the camera. If permissions aren’t granted, the plugin might not function properly.
Check for Conflicts: Other plugins or elements in your app might be causing conflicts. Try disabling other plugins temporarily to see if that resolves the issue.
Inspect the Console: Open the browser’s developer console (right-click and select “Inspect”, then go to the “Console” tab) to check for any errors or messages that could indicate why the plugin isn’t working.
Update the Plugin: Make sure you’re using the latest version of both plugins. If there are any updates available, try updating to see if that resolves the issue.
Best Regards,
Zeroqode Support Team
