Question about measuring distance and angles
Hi. Just wanna ask a question. Can I make an app in bubble where I can mark a point on a picture and measure the distance between two points or angle between two lines? Thank you!
Anyone?
@shu.teopengco You can get x/y coordinates for points on the page. Angles might be doable with approximations. Alternatively, you can build a plugin.
Thank you! Coordinates may work for points. Maybe I need some coders to make plugins? Haha
