Hey everyone!
I am in the editor trying to add a slider or radio input and neither are working. When I create a new app and try there they do work. In my editor for a project I’m following along with they don’t. The slider I can’t select min/max to change the values. The radio buttons I can type my choices but they aren’t showing up either.
Perhaps you can experiment using another browser. Also … explore if there is a plugin on the page that may be causing conflict. In the forum there have quite a good number of folks experiencing problems with plugins. Bubble just added some functionality that requires plugin authors to update their plugins.
I’ve tried all different browsers, it works within the same browser just in a different app. It’s file specific to the app I’m making where the issues lies.
No sorry, forget the mention of file as that’s just confusing. In my Apps section, I have 3 apps. The only one I’m having an issue in is the first one. I don’t encounter these issues in the other apps. In all other apps, radio buttons and sliders work besides the one I’m working on, the first app. Thanks for your patience.
Compare the versions among the three apps. Do not update them yet. The differences may guide you towards where the problem may lie with possible Bubble updates “messing up” that input:
