Hi Guys,
I’m trying to create a rating system but it seems like rating input doesn’t work properly. It stores the wrong values. I shared a screenshot below.
I put the right values into comment sections so you can see the difference. Is there anybody who faced this problem? How did you solve it?
Thanks,
Batuhan
I suspect there’s a problem with your workflows.
Have you tried imputing ratings while in debut mode? You can go through the workflows and actions step by step to see how they’re interpreting the input. That’s probably the easiest way to figure out where it’s behaving differently than you expect.
Thank you for your answer. I changed the step as “1” and it works very well now.
