Reapeating group cells are not showing in ui builder
Hi, can you please share screenshots for a better understanding.
no cell in repeating group why?
Hi did you try changing the minimum height of the row to PX instead of 100%. E.g. 100px
Just to check what happens.
nothing changed
Can you please create a brand new repeating group in a new page to check whether the behaviour is same everywhere?
same as previous
What are you expecting to see here?
cells in repeating groups
I can see 4 cells here.
got it thanks there was a problem in selction of colours thanks
You can mark it as solved since thread was a problem and looking for a solution.
A very simple thing can waste hours of our works. Marking as solved save hour of others.
Good luck to you. :heart:
