Recaptcha visibility issues in new responsive engine
I just switched to the new responsive engine and though my recaptcha didn’t have any issues before, I now have to refresh the page TWICE before the recaptcha becomes visible. Is anyone having similar issues?
** The Issue only started happening after I switched to the new responsive engine though I have already configured it to be visible on page load.
I’ve the same problem - did you find a solution?
@johndmillican not yet.
I hacked it by work flowing - not visible / display on page load. It works perfectly now
YAS!! just did what u said and it is working now. Thank you!! You are the best :+1:
Thanks for the tip! I was having the same issue and this workaround solved it.
you’re very welcome brandon
