I managed to create a workflow that accidentally deleted a lot of my data. I had a search function that if this elements invoice # matched the cell invoice # it was deleted. The current cell had an empty invoice number, so the search returned all of the elements and deleted them. Is there a way to recover data once it is deleted? I tried reverting to an earlier update, but the data was still gone at that time, should I revert to an earlier time?
If you have the ability to restore data, the app is https://hvac_designer.bubbleapps.io and it was the payment elements that were deleted. It would have happened about 2 pm EST. May 11, 2016
This is Adam, I am working on the same app as what matt just posted. I have created a related post in the bug category about searching for blank entries returning all entries ( Search of a blank entry will return all elements). I will follow up with email about the data recovery in this case. The data was lost from the live version.
