Repeater group does not display creator data
The repeater group is not showing the content type creator data of the current cell.
With the information I put, I should pull the data from the creator user of the current cell.
Captura de Tela 2021-07-07 às 09.35.23
Hello,
Thanks for your post! One thing to check here may be privacy rules to make sure that the user who is viewing the application has the permission to see this creator’s photo. It may also help to use the debugger to inspect “Image F” when previewing your application to learn how its data source is evaluating. Let us know if that helps or if you have any more questions!
