Hello,
I have that displays 1 cell (1 row, 1 column). users can click skip to view the next item.
Users can create projects and all projects are displayed to all users using the RPG above
I would like users with free plan to have only one of their projects displayed in 24 hrs
while users with a paid plan would have 10 of their projects displayed in 24 hrs
My DB is structured thus:
User>Projects
User> Plan (Free or Paid)
Thanks for the reply @makara .
This would have worked if i was restricting the current user viewing the project.
How every i am trying t restrict the creator of the project. for example if the creator has 4 projects. when the viewer (another user) take action on that project, it triggers a 24hr pause for a projects of that creator, so that the creators project will only appear again for other users after 24hr (which means 1 project displayed per day) for free users (creator).
for paid users, 4 projects would be4 displayed per day
If it is, simply.
Create a field “read count” (type item) and
When page is loded, add the current item.
with the condition "when read count :count<1”
And then you make the RG data source a read count!
Then delete the read count every day in the schedule api workflow.
Had to watch a youtube video to implement it, your idea worked perfectly. i implement the count on the users plan timer which resets to its limit every 24hrs(daily limit). first triggered with signup button. Thanks @makara
