Repeating Group: How to combine same data and display?
There are a number of itineraries that have different destinations and different travel dates.
I want to achieve is to display itineraries in Repeating Group. But, I don’t want the same destination+same departure date+same return date over and over; instead, I want to show the same combination itinerary only once, but show the sum of the # of travelers of each itinerary.
For example, if I have 3 itineraries with the same destination + same date 1 + same date 2, but the number of travelers for each are 2 and 2 and 1, I want to display this itinerary just once but the # of travelers should be 5.
Can anyone help me with this?
Thanks.
You can use the command :Grouped by to group the result of your search by one or more parameters.
