Repeating group needs to show data not selected in multi dropdown
i currently have an option set filled with allergies called tags connected to a data type called menu. there is a multi dropdown connected to a repeating group, which shows the menu items that have the selected tags in the repeating group. My problem is i want the repeating group to do the opposite and show the menu items that don’t contain the selected allergies. Below is the advanced filter to show the the selected data.
How do I change this to show not selected options or is there an easier way? Thanks!
Hi there, @120440132… if I understand your post correctly, it seems like all you might need to do is change :count > 0 to :count is 0. Have you tried that already?
Best…
Mike
Hi mikeloc, That worked it seems I was just massively overthinking it. thanks so much for your help
