[Request for help] Stuck on an AirDev Canvas tutorial workflow
Hi all - first time Bubbler here and hoping this is the right place to ask this question.
I’m going through AirDev’s Challenges and working on the “Upvoting app” whose requirements and database structure setup can be seen here: https://canvas.airdev.co/task/database-setup-1576114192175x468061768545931650 or see below:
When a user clicks on the left “up arrow” icon, it should increase the number of likes for the respective post. My design tab looks like this:
I’m having a hard time figuring out the right workflow to accomplish this. I thought it would be something like the below but it’s not working and I’m sure I’m doing something wrong.
Thanks in advance for any help and please let me know if I need to provide any more info/screenshots
Brett
Hey there, :wave:
I think you can do this:
Step 1: Make changes to Post (post from repeating group). Choose likes > then add current user to that list.
Does that work for you? I am not sure how everything is set up on your side without seeing the editor. This is just my best guess. :blush:
@j805 www.NoCodeMinute.com
Hope that helps! :blush:
As per your instructions, I did:
and now I have:
Not sure why I didn’t get that the first time around. Learning curve…
Thanks for your help!
No problem! Glad it helped. :blush:
  • One-on-One Tutoring
  • eLearning Hub
  • Video Tutorials
  • No-Code Classes
