Reset Prefilled RG Input Fields With A Button Click
I have created this page (image attached). This is how the page works:
When the product code search box has a value, the product description, selling price, vendor cost, and net sales fields auto-populate with their corresponding values.
When I click on the green add icon, it saves the information in a quotes table.
The second part of this screen then populates values from the quotes table. I am using the RG and have added a group as well. The input fields in the repeating group’s initial values have been set to pull records from the quotes table.
I need the input fields in the repeating group to reset when the save quote button is clicked.
Is there a way to achieve this?
Thank you.
Workflow action to reset relevant inputs or workflow action to reset group (you reset the group that the inputs are contained by)…since you are using an RG, you are likely to have better results with reset inputs workflow action
