RESOLVED - Drop Down Box Not Changing
I cloned the Fitness Trainer App and have been making changes to it for my specific use. For the most part is has been good, but on the first page there is in an initial Register popup. Within the popup there is a drop down box where someone can choose if they are a Fitness Seeker or Trainer.
I have gone in and changed the Static Choices for the drop down to be the values I want, yet whenever I preview the app, it only shows the two original drop down options.
There is the only on register pop-up on the page, and the workflow is pointing towards the correct drop down, but the choices aren’t changing. Any advice or anyone seen this issue before?
Thanks
RESOLVED - The link in the Header opens a different registration form from the one I changed - D’oh!
