I am trying to figure out why my group is not resizing as it should.
The responsiveness I’m trying to mimic can be seen on reddit. Here’s what happens when you have it full screen:
When you shrink the screen to small to mobile size, the shape repeating group box shrinks to fit the he screen size (and continues to shrink in tandem to fit the size of the screen).
For the life of me, I can’t figure out why I can’t replicate this on my experience for this blue group I have. It doesn’t shrink as I’ve expected.
Here are the settings - for the blue group
For the text boxes
large:
small:
Try it button
When I try to resize, the blue group and the text inside is not resizing as per what I’m looking for on the reddit example
image1100×883 76.1 KB
When I try to resize, the blue group and the text inside is not resizing as per what I’m looking for on the reddit example. In addition, the Try IT button should also move from the right of the screen, to the bottom of the text so it can be seen.
Is it me, or is there something with bubble that can’t do this? Thanks
Anyone was able to find the reason behind this? Do we need to use condition to handle this or we do have any better approach to this?
