Do you guys know what responsive setting to have to make a row like this:
convert into still a row but layed out like a column when the page size gets too small like this:
This is just a simple row element with minimum widths set on each of the text and picture elements. If the minimum widths are 500 px each and the page is greater than 1000 px, it will be in row form. When the page is less than 1000, there won’t be enough room for both elements so it will wrap the picture element to the bottom
oh that simple thanks
