Hi All,
I am making my page responsive it is visible as
in Laptop layout.
But the File uploader is not shrinking as other input fields while I had made the layout as same as of other fields then also.
Please help.
Hi All,
Please help.
Are you in the new responsive engine?
Check to make sure that the minimum width of the uploader element and it’s parent group are the same as the other groups.
One issue is that all of the other groups have another group beside them. The uploader group does not, so it’s shrinking in width at a different point. You may need to manually edit the minimum width of the group at certain page widths in the responsive editor.
