[RG LISTS]How to sort or filter a repeating group using checkboxes
Hello Bubblers , :grinning:
Hope you are fine and safe wherever you are?
How do i sort or filter a repeating group using checkboxes?
These check boxes filter by the category drop down 'Text" whiles entering into the Database
Kindly Assist Thanks :pray:
Just set a condition on the RG (middle tab on the RG popup) for when the checkbox is set. The condition will change the search params for the RG.
Here is an example for you …
https://buildingonbubble.com/block/dynamically-filter-a-list-1458840720641x659248893977690100
ok Thanks
Thanks but this example filters it by one constraint of category
This here is by 3 contraints at the same time Job type,Category and Experience level with thier individual contraints on just that single RG
OK, so you may want multiple selections instead of just one …
https://buildingonbubble.com/block/a-list-with-multiple-1472220949220x795693731957964800
And then make three versions of that.
