Seeking paid-for help from developer
Hi, I got stuck with this problem and bubble forum is no help (let alone bubble support):
If there’s any experienced developer able to solve my problem I’m ready to pay (reasonably) for the solution. Kindly DM me with your request.
Please consider that I don’t want to use 3rd party map plugins so I would either use the standard bubble map element or an HTML element with the google map displayed inside. I experimented with both without success.
Send me a DM with an example of the issue and I’ll see what I can do. If I can fix the issue on my own I’ll let you know and send you the quote when I’m done.
Book a session with the guys at @copilot, they will have no problem helping you out!
Hi @Andrew_Morris,
I hope you are doing well. If there are openings open for junior bubble developers, I would be grateful for the chance to apply and learn under your guidance.
You can check out my portfolio link here. Thank you
Resume gimanthaDolawatta
Thank you again for considering my application. I’m looking forward to the possibility of working and learning with you.
Your response is greatly appreciated.
Warm Regards,
Gimantha Dolawatta
