Select Pdf Issue I need Help
I am using Slect Pdf in the demo mode and for some reason it is limiting the amount of text boxes I am displaying with data…
When I generate the webpage everything is but when i use the plugin to generate the PDf i am missing a number of text boxes that display data…
Does the demo Limit the number of text boxes it converts?
Please help
SelectPDF should generate the webpage as it is. If it is skipping data you may have Privacy rules set that are blocking access to that data.
I have the same issue. It was working perfectly and all of the sudden there are missing fields. I have tried changing the settings to allow for more processing time however issue persists.
UPDATE:
This issue is resolved when switching Rendering Engine from Webkit to Blink.
12
