Server side problem with plugin “Encode Hash & CryptoJS · BEP” (Hashify)
Hi @renatoasse
I’m using your great plugin “Encode Hash & CryptoJS · BEP” but today the action in the screenshot below started throwing the error:
Workflow error - Temporary error connecting to Hashify - Convert Text to Hash - Data (raw message: error code: 500)
Can you please help? It has been working smoothly for several months and I didn’t change anything. Thanks in advance,
gl
The problem is not present anymore.
Hey @gianluca1 ,
Thanks for reaching out! The error you were experiencing was most likely caused by the Cloudflare outage that happened earlier today.
This affected multiple services across the internet, including the infrastructure that the plugin relies on.
The good news is that everything has already been normalized and should be working properly now.
Thanks for using the plugin!
Best regards,
Renato
Thank you!
Hi @renatoasse please be aware that, for the last two days, the plugin has been throwing this error:
Temporary error connecting to Hashify - Convert Text to Hash - Data (raw message: error code: 523)
I didn‘t change anything on my side. Any clue? Thanks in advance.
I am having the same issue. Maybe it is also related with Cloudflare (https://www.cloudflarestatus.com/)
