Setting focus on input element in other pages - shortcuts approach
I have a plug-in (air keyboard shortcut by @ZeroqodeSupport ) and I would like to put it in the header to map global shortcut.
How can I use the “set focus to” when input/searchbox is on a page different from the header page?
Maybe I can use “go to page…” + something I can’t identify.
Or, maybe, can I manage shortcuts without the plug-in?
Hi @gianluca2, thanks for reaching out.
If I understand you right, you would like to use this plugin inside a reusable header element. Unfortunately, this will not work, you have to add the element AirKeyboardShortcut on every page that requires this plugin’s actions.
Inside each AirKeyboardShortcut, you define the key combination or sequence and create a new event in the workflow when AirKeyboarShortcut is triggered.
If you meant something different, please share with us more details regarding your use case, screenshots of your setup, and workflows.
Looking forward to your reply.
Best regards,
Zeroqode Support Team
