When creating a sign up, can you make it so more than just email and password need to be inputted to sign up. Such as First and Last Name. Also can you make it so the password has requirements, such as has to be 8 letters
Thanks in advance.
Thanks in advance.
You can set some password requirements on the Settings page under the Define a password policy checkbox. As for the extra input fields for Sign Up, I believe that should be fairly easy to add, I just haven’t done it personally to give you the steps to accomplish it.
