Simple front-end to display chart using data from PostgreSQL?
Is this possible with Bubble? We currently have a native PostgreSQL database (with plans to move to cloud) and want to build a simple front-end which will accept a query from a user and display the result with in a chart with a few additional metrics.
Would Bubble be able to handle this? Any tutorials?
Bubble’s lightweight docs …
Manual, look for SQL Database Connector … https://manual.bubble.is/using-plugins/special-plugins.html
Reference … Introduction - Bubble Docs
Plus check older forum posts on “SQL”.
In summary, there is a way to retrieve data, there are a bunch of limitations and another bunch of workarounds.
Likely the hardest step will be linking in additional metrics with the results from the query.
