SOLVED: Help with Using CarQuery API and API Connector
I’m trying to use CarQuery’s API using the API Connector
http://www.carqueryapi.com/documentation/api-usage/
When I manually create a query based on their URL (see below), I get data I’d expect to see.
https://www.carqueryapi.com/api/0.3/?callback=?&cmd=getTrims&make=honda&year=2018&model=accord&full_results=0&sold_in_us=1
I thought I was setting up the API connector correctly (see below). Here’s the GET call:
https://www.carqueryapi.com/api/0.3/?callback=?&cmd=getTrims&make=[make]&year=[year]&model=[model]&full_results=0
But when I go and initialize the call, I get a bubble message saying the call is JSON/XML but the call is returning text. From reading CarQuery’s material, I thought their API was returning JSON data type.
CarQuery also mentions $.getJSON and shows a code snippet (see CarQuery url at top). But I don’t know if I need to do something with it in bubble in order to use their API?
Anyone have a thought on how to get the CarQuery API working with API Connector?
You will need to remove ?callback=? so rather than say,
https://www.carqueryapi.com/api/0.3/?callback=?&cmd=getMakes&year=2000&sold_in_us=1
you would call,
https://www.carqueryapi.com/api/0.3/?cmd=getMakes&year=2000&sold_in_us=1
then add a header with the key Content-Type & the value application/jsonp
that should sort it out.
Thanks Jarrad - that fixed it! Much appreciated.
