Using a slidebar menu when I enter options into them there not visible as a current option
Type them in – This SlidebarMenu’s current option is “Home”
I have typed them into the option manually, but there still not linked to anywhere. On my page the logo is the should be “Home”, The + sign link to the “Submit Coupon page” and the Login and Sign Up should link to the login or sign up page!
Create a page on the forum app, or provide a link to your editor, and it’ll be easier to help.
Thats perfect! I figured it out I hadn’t applied an action with the event!, Thank you!
