[SOLVED] Using "unique elements" doesn't get rid of duplicates when using merge
This repeating group is showing duplicates:
44%20PM
I used “unique elements” at the end, but that’s not working, probably because it applies to only the list after the ‘merge’, not both lists in the source.
Anything I can do? Thanks!
My bad, I was creating a duplicate somehow. I didn’t even need “unique elements” in the end.
