Speed of Duplicating Elements Vs Conditions
Hey everyone! (TL;DR at the end)
I’m reaching out to the community and veteran Bubblers for advice before building my app in a way I might regret later.
Context: I have 50 data fields within a “Country” data type, including bollards, poles, cars, and others. I’m creating a “dynamic” repeating group to display different content types. This will be placed on a page showing 50 categories, each with information specific to that country.
Here’s an example of how it would look: There will be 50 sections like this. For instance, the bollard section will display all bollard elements in that country, and so on.
Question: Is it better to have 50 sections on the page, each displaying its respective info, or to have one section within a repeating group of content numbers? The repeating group would dynamically create the necessary sections based on a list of numbers provided (via JS Tools List of Numbers element).
In the single section within the repeating group, I would check the current cell’s index to display the correct content. For example, “if current cell’s index is 1, display country’s bollards; if current cell’s index is 2, display country’s poles,” and so forth.
Each section would include a repeating group displaying the category images, with 50 conditions to show the correct images based on the parent repeating group’s current cell index.
TL;DR: Should I predefine 50 elements on the page, or dynamically create them via a repeating group and use conditions to display the right data in each section (with each section having 50 conditions)?
