Speed of workflow - SLOOOOW
Hey all, I have a form on my site where users can click checkboxes and as the users clicks on them it either adds or removes that entry to/from the database. There are hundreds of line items that a user can select but even one selection is taking up to 10 seconds for the workflow to work. Why does that happen? Am I setting up the workflow all wrong?
Workflow:
Front end:
What are your constraints for both of those searches?
Oh, did you mean the search box?
The search box is using the Search & Autocorrect plugin and updating the table accordingly.
Instead of doing a search on the make change I think you could access the right account/venue by using the row’s value, that way you don’t have to search for it again.
On a side note regarding UX, when a change is immediate it is best practice to use a switch instead. When it comes to checkboxes these are used alongside validation buttons.
Thanks for the response! Can you explain this a little more?
“On a side note regarding UX, when a change is immediate it is best practice to use a switch instead. When it comes to checkboxes these are used alongside validation buttons.”
Do you mean something like a toggle or an icon the user can click on instead of a checkbox?
I should have included that! Here’s the constraints and the additional part of the workflow
Constraints: there isn’t much here. The toggle is just to show or hide an element but here are the checkbox constraints
Workflow:
Yes if the action is immediate use a switch instead of a checkbox, like the one you have above.
