I start a project and a simple problem to start.
The project is based on a form (annual data entered by the user). With the given data, the application must automatically generate monthly tables (see image).
Question: how can I do this calculation?
I’m not looking for a step-by-step guide but tips for getting started.
I have already made the form but I can not turn this annual data into a monthly table.
Is there a way to make an excel spreadsheet the foundation of a dashboard? For example, I have a spreadsheet that shows accounts opened, accounts pending, etc. that I am constantly updating. I want it to where I can make my updates to the spreadsheet but it updates on the user’s dashboard in bubble. Is that possible?
I am sure that there is a free solution- although you would have to build it out piece by piece.
I would definitely weigh out the time it would take you to develop vs. validate a business model. Lots cheaper to integrate for 6 months to test a hypothesis than it would be to build custom to end up being “wrong” in the long run.
