Stipe Connect Issue
Hello,
I am getting the attahced error when trying to send payment to seller. I have built a marketplace. We are based in the UK but our prices are in USD & when I want to send the payment to an influencer, this is the error we get. Any ideas?
Looks like you have a currency mismatch - If your in UK then your Stripe acc will be in GBP so you need to send GBP to the influencer - it will do the currency swap for you. Or use a currency API to work out the conversion and send the right GBP amount to match the USD amount
Ive actually figured it out… Stripe actually does that for you.
It was a simple issue… The charge ID was incorrect. Once I realised & fixed it. Then we were sorted.
