Strange "slidebar" appear on my index page?
Some wierd slidebar has appeard and I can’t find where it is or how to remove it but when I preview my page it appears? Can’t find it in the elements tree either?
(following the Bubble recipe course tutorial)
Hi there, @Orbit… use the element search (next to the page selection dropdown) and search for “slider”. If it’s showing up, then it’s got to be on the page, and you should be able to find it with the element search. Once you find it, you can select it and delete it.
Hope this helps.
Best…
Mike
Hey @mikeloc! Thanks! i found it under a new Header template i made… :rofl:
