Sorry but, I’m completely lost with backend workflows…
In my app, I use an hidden variable to build a text to send by email.
Build of the variable (using conditions and checks), send email with backend workflow (body = my text variable), then display the text variable in a group for the user.
My problem : the text sent in the email is lot the same than the text displayed i’ the group at the end. But both come from the same variable…
Is there any known issue or consideration to take into account when working with both variables and backend Workflow?
@cmarchan, so if I’m correct, backend workflow can’t use “Current things or page”. Am I right saying that I can pass a search for thing (based on the current thing uniq if) to the backend workflow?
I’ve to give a try. I am just asking in case you’re connected to the forum .
